RE: Speed Measuring?
the pitot tube won't work properly in a car, it's going to get odd readings as it's so close to a solid object (the ground)
and the slower you're going, the larger the error is going to be.. these things were designed to measure aircraft speed and to be accurate in a range of speeds that are much higher than most RC cars are going
