Speed Measuring?
oh yeah, when i did the speed calculator for my rc18t, it said top speed is 76mph without any tire ballooning.
that little car is RAW, even going in a straight line is hard to do, you have to BABY the throttle up to top speed (which i havent found enough room to top it out[X(]) i punched it from a stand still, and it two seconds, it spun, did a front flip and shot off two tires.
funny thing its only a 4500KV motor with a 28 pinion and 57 spur, but 600watts!! and i still cant gear it down
ok, i'll get off my pedestal
SK, BANGLADESH
@ shark,
that calculator should have tossed a warning/note at you that above 40-45 it's going to be off as air drag is a huge factor as you get faster
I'm sure your RC is fast, but it's not 76 mph fast
ORIGINAL: sloppyG
@ shark,
@ shark,
the calculation was also without ballooning.
ive been around rc's for awhile, and when a 3.3 4-tec looks slow, you know its cookin.
ORIGINAL: sloppyG
it won't work in a car
it's a pitot tube speed sensor, it's for planes
ORIGINAL: Moontan13
Interesting device! Works with telemetry and data logging too. Verrry nice!
ORIGINAL: cremation101
try this http://www.eagletreesystems.com/Stan...standalone.htm
seen these and they seem to work well
<br type="_moz" />
#31
SK, BANGLADESH
the pitot tube won't work properly in a car, it's going to get odd readings as it's so close to a solid object (the ground)
and the slower you're going, the larger the error is going to be.. these things were designed to measure aircraft speed and to be accurate in a range of speeds that are much higher than most RC cars are going
#33
ORIGINAL: The_Shark
i bet money on that sir. it does atleast 70 no less, the car is also teeny tiny and i have it slammed to the ground with the biggest battery it will fit.
ORIGINAL: sloppyG
@ shark,
@ shark,
#34
ORIGINAL: sloppyG
You know what, now that I think about it...you want the pitot-static probe LOW and out in front so you can call wind effects negligible. Haha, way to use all of your fluid dynamics courses there, Victor! Guess I shoulda thought it through the first time!! Oh well. Point is:
PItot-Static probe low and forward will give you great readings!!
<br type="_moz" />
#35
ORIGINAL: DaveG55
Also, if I understand airspeed correctly, a radar gun will not give an aircrafts airspeed but it's groundspeed instead.
<br type="_moz" />
#36
I think I found one nearly perfect for my needs:
http://www.radargunsales.com/Speedtr...adar-unit.html
It's not handheld, but rather tripod mounted.
#39
ORIGINAL: Moontan13
I was thinking of a used one via Ebay.
http://shop.ebay.com/?_from=R40&_trk...All-Categories
Saves you all of $33 over a new one with a guarentee
ORIGINAL: sloppyG
this is the best economical way, unfortunately I get the feeling most people would rather spend $100 than do 3 minutes worth of math
#41
ORIGINAL: sloppyG
yeah, it seems like people are willing to go through a lot of trouble and expense to avoid doing 3 math calculations
me, i dont care about actual speed, if its a blur, rips off the tires and takes off like a jet, its fast enough for me.
#42
It's not the math. Even if I thought I could operate a stopwatch and a r/ccar, there's no way I could do that while flying a heli. Good method for little wood cars rolling downhill though.
#43
SK, BANGLADESH
ORIGINAL: Moontan13
It's not the math. Even if I thought I could operate a stopwatch and a r/c car, there's no way I could do that while flying a heli. Good method for little wood cars rolling downhill though.
I think it is the math
