ORIGINAL: elan120
ORIGINAL: lyka
Hi Jon....Not in our case, below or above there is no difference.
Just remember to have cut the stab tube two millimeters
On the wings, no difference gap.
Hi Lyka,
Thank you for the input. I am also having similar problem where stabs don't fit against the fuselage flush, so hoping you have some suggestions.
Could you help explain further what does it mean by cutting the stab tube by 2mm? The fit, as I see it, is where one side (either top or the bottom) of the stab come in contact with the fuselage already, and that is preventing the other side of the stab from fitting against the fuselage flush.
If your stabs fit against the fuselage properly, then perhaps it is just our plane that having the inproper fit.
Thank you,
Kevin
Hi Kevin.... in the first time, when I install the two stabs, I see it gap difference but in the top y botom the same...2mm cut off tube stab and perfect... yes, I think that you have improper fit...bad luck...my god !!!
cheers
Andres Girabel
