Hagar 9 T-34
I have started on my T-34. I was very pleased with the covering and packaging of the plane. However, I have run into some problems.
1) as mentioned, there was NO FUEL tank included. However, one quick call to Horizon and it was on the way. Great customer service.
2) When I went to install my wings (on the fuse) after gluing them together, I found that one of the bolt holes was WAY off!!!!!!! I had to drill a larger hole in the wing so the 1/4-20 could get a straight shot into the blind nut.
Also, I noticed that the wing is slightly off center. It stick out just a tad more on the left than on the right.
Other than that, it looks pretty good. I have a OS70 that I will be installing. For the time being, I am just going with the fixed landing gear. I may upgrade at a later date, but for now fixed will do. Later.
