RCU Forums - View Single Post - Sanding edges
Old 02-06-2011 | 03:55 AM
bps's Avatar
bps
Default RE: Sanding edges
I use pvc pipe cut in half lengthwise. Comes in many different sizes. Cut the length pipe you want, split it lengthwise, glue a handle on it and use rubber cement to glue sandpaper to the inside. I use this kind of sanding block for many different jobs that need a rounded edge including wing tips, stab and rudder edges and so on.
