Sanding edges
MN
is there a sanding block to sand down the leading edges? or what tips are there to sand down the leading edges and wing tips when building a kit? I'm building a TFP-47d ge and tomorrow i should be done with sheeting the stab and the elev. and am wondering if there are any tips that make this easier. thanks or any tips they are much appreiciated.</p>
All leading edges are a circular shape.
This tool is useful:
http://www3.towerhobbies.com/cgi-bin...&I=LXK325&P=SM
You can find more ideas here:
http://www.rcuniverse.com/forum/m_94...tm.htm#9415293
I use pvc pipe cut in half lengthwise. Comes in many different sizes. Cut the length pipe you want, split it lengthwise, glue a handle on it and use rubber cement to glue sandpaper to the inside. I use this kind of sanding block for many different jobs that need a rounded edge including wing tips, stab and rudder edges and so on.
My Feedback: (118)
TX
Masking tape is a secret weapon for sanding. Protect the sheeting adjacent to the leading edge or wing tip prior to sanding. I use the blue painters tape in different widths for this task.
When sanding wing tips I usually wrap some masking tape over one end of a sanding bar. This wrapped end rides on the wing skin and prevents cutting into the skin.
You cannot have too many different sanding tools.
Bliksem
Bliksem
The best tool for this is a good (Stanley) low angle block plane. You can get the shape very close and accurate and then finish it with progressive grits of paper on a sanding block, then finally by hand. I actually love shaping leading edges. It is the most important part of the wing really.
