RCU Forums - View Single Post - new axiome ep
Old 02-06-2011 | 11:55 PM
ohadzarko
Default RE: new axiome ep
The model flies beautifly, it has excellent rudder control , the same as elevator. There is slight coupling(maybe because the forwardCG which I prefer). The model arrives with the opening in the tail skid as standard although I enlarged it a bit because of the hot weather. In the center of the fuselage at the bottom I have added another opening.
What I dislike about the model is the weight of the wings (420g each not incl. servos) making it 100g more than the standard.
And because I put the elevator servos in the tail, the battery tray is haif way under the engine, making inconvenient to access.
I think the engine you chose will put the model on it's upper limit with a 1180g battery, take note.
You did a good choice, and I wish you lots of enjoyment from your new model.
Ohad Zarko
F3A Israel Team
