RCU Forums - View Single Post - Evolution 61 Stalls going Vertical
Old 02-09-2011 | 12:27 AM
tipstall 131's Avatar
tipstall 131
Default RE: Evolution 61 Stalls going Vertical
May I make one more suggestion?
On my .36 the fiitings on the remote NVA started to leak after a while (3 years). The seals on these fittings are the fibre type and they seem to go bad after some time. This caused severe leaning and all sorts of troubles. Can you see bubbles in the fuel line from the RNVA to the carb? If so, that could be a possible problem. The fix is simple, just get replacemant gaskets and seals.
Hope this helps.
