RCU Forums - View Single Post - Evolution 61 Stalls going Vertical
Old 02-09-2011 | 03:30 PM
earlwb's Avatar
earlwb
Default RE: Evolution 61 Stalls going Vertical
I don't remember reading that the OP had checked the fuel tank. My apoligies if it was. Usually when you point the nose up and the engine dies, that is a sure sign that the fuel tube inside the fuel tank as a tear or hole in it. Usually the tear or hole forms right at the joint where it slips onto the fuel tube going through the stopper in the fuel tank. So then when you point the nose up, the air void in the fuel tank moves to the front of the fuel tank and the engine suddenly sucks some air and dies.
The other thing is the clunk on the fuel line inside the fuel tank. It may be rubbing up against the back of the fuel tank and being obstructed partially. The clunk should not quite be able to reach the back of the fuel tank.
Oh yeah, having the fuel tubing and clunk getting stuck or jammed into the front of the fuel tank will do this too. When you point the nose of the pane up the engine sucks air again and dies.
