Telemetry Sensor/engine temp
Hi all...may I assume that the wire for the engine temp sensor is able to stand the engine temps without melting the coating. Also, can I add some length to the wire as it is not long enough for my application...will put the extension away from heat. Will adding length affect acuracy...thanks...Bo
ps: haven't purchased the rpm sensoe yet, byt plan to...will adding length to that affect it's accuracy ...am installing on an EVO 45X gasser and note that I should use the backplate to mount a sensor...anyone had success with this....
...all of this is way cool.....
