RCU Forums - View Single Post - Case for 12X
Thread: Case for 12X
Old 02-12-2011 | 10:01 AM
Jeffpro's Avatar
Jeffpro
Default RE: Case for 12X
ORIGINAL: darryltarr
Jeff,
The original case is just fine. Simply adjust the slidable compartments arround and you it will fit your TX perfectly (even TWO if you want).
Rgds.
Here's what I don't get. Your photo shows what the addendum to the manual shows. When I try it, the base section of my antenna won't go down far enough. It'll go to about 45 degress, and that's it. Even if you remove the foam from inside the lid, you can't close the case without potentially breaking the antenna. What am I missing? Has JR changed the amount of travel on the antenna or something?
