Case for 12X
TN
Can anybody recommend a good case for a JR 12X? I got one for Christmas and the case that comes with it is a poor fit. I tried what the addendum to the instructions recommended, but my antenna won't fold forward far enough for the lid to clear.
I am amazed that a transmitter of this quality comes with a case that doesn't fit.
Hi,
You can really find good cases here:
http://www.skbcases.com
and also here:
http://www.gatorindustrialcases.com (see utility)
They are not exactly for RC transmitter but they have a huge selection of cases, maybe you can adapt one by modifying the foam interior.
I use a SKB golf case to carry my pylon planes. The quality is really good.
-Juan
and also here:
-Juan
TN
ORIGINAL: darryltarr
Jeff,
The original case is just fine. Simply adjust the slidable compartments arround and you it will fit your TX perfectly (even TWO if you want).
Rgds.
Jeff,
Rgds.
Hi Jeff,
I have teken some more photos so hopefully they will help you to rearrange your case accordingly. On my DSX12 the antenna base is full forward to about a 70 degree angle, confirm yours only moves to 45 degrees.
The JR case also fits my Futaba 14MZ perfectly.
Good luck.
Rgds.
Good luck.
Rgds.
My Feedback: (14)
I didnt have a case, so ordered a yellow case from Pellican. Waterproof, and foam filled. Big enough to put in charger and other accessories. Then some one sold me his 12X case, and im not using the Pellican. Its nice but a bit heavier. I could sell you my Pellican case.
TN
Hi Jeff,
Good luck.
Rgds.
Hi Jeff,
Good luck.
Rgds.
