ORIGINAL: blw
Throttle delay is probably due to using a remote needle valve.
Throttle delay have nothing to do with using a remote needle valve.
ORIGINAL: blw
It would seem that using a larger id line would put the engine on par with other 2 strokes if a throttle delay is noticeable.
I've heard this misconception many times. Just how are you going about to putting larger ID fuel line to the engine?
If you getting throttle delay, it is most likelly due to the improper tunning settingsof the engine.
