ORIGINAL: gr8flyer55
If you meant my cdi system, here's a photo of it connected to a Cox 1.4 cu.inch chainsaw conversion I did.
John
I have one of the Cox Rhino 1.4 engines like you have converted. Mine came to me with a spark plug to glow plug adapter. I was going to try gas-glow, but may now use the RCEXL ECDI sytem I have and run it spark ignition with gasoline. Have you had to rebuild the carb, and are parts available and from whom?
I need a hub/prop adapter. Where did you get the one you have?
What performance figures are you getting from the Cox/Rhino?
Thanks.
Sincerely, Richard
