RCU Forums - View Single Post - Remote ignition glow plug
Old 02-13-2011 | 05:38 AM
Oberst
Banned
Default RE: Remote ignition glow plug
ORIGINAL: Richard39
Good morning Pete... Is the soder plug the black plug that is put on the glow plug and has a sliding wire connection? I have one but the black head plug will not seat down into the 120 Magnum head... I do not under what you mean by the allen exhaust bolt..... or how you are making the ground..... thanks for your help...
Richard
Morning Richard.
No, soder plugs is in the first photo. You use that for your ground. The Allen bolts is used for 2-strokes to attatch the exhaust. If you're using a 4-stroke just find a place close to the glow plug on your engine to bolt it down. It will be the same concept, just a different type of motor. I took these pictures just for you. Study them, it will explain everything.
The boot that pops on your glow plug can be removed or trimmed if need be to fit any engine. I trust a spring loaded clamp system for the glow plug, before I trust something I have to pinch on. JMHO
I hope I helped.
Pete
ID:	1562727   Click image for larger version
ID:	1562728   Click image for larger version
