RCU Forums - View Single Post - Remote ignition glow plug
Old 02-13-2011 | 12:41 PM
Oberst
Banned
Default RE: Remote ignition glow plug
ORIGINAL: Richard39
As they say Pete.... a picture is worth a thousand words... everything is clear to me now.... flew today with the setup and all went well with the remote starting.....
At the hobby shop yesterday they introduced me to the Traxx glow plug connection... very small and tight.. very tight... about $1.80... I have about 4 different connectors/heads that go on the glow plug... testing what is best for this hard to fit Magnum 120 four stroke... I like the one you have in the pictures but it will not go down into the hole where the glow plug sits... very tight and small area to work in... The push and twist connectors fit but have had a problem with them coming off.... Thanks for all of your help.... One more day of testing and then the cowl gets installed....
Richard
Fantastic. Now you know what the deal is with those things. Good luck with the testing. It should pass your testing if it worked earlier.
Pete
