RCU Forums - View Single Post - Guessing this is the steering servo
Old 02-13-2011 | 07:23 PM
The_Shark's Avatar
The_Shark
Default RE: Guessing this is the steering servo
you can try to put it back together (spring first then center plastic peice) but to me it looks like the teeth are gone and also see if you can find the screw to hold it to the sevo, if it worked loose, those two halves can seperate.
i have never repaired on of these, but it looks like you remove the top plate to repair it.
