RCU Forums - View Single Post - removing ultracote adhesive
Old 02-15-2011 | 06:16 AM
SoCalSal
My Feedback: (16)
Default RE: removing ultracote adhesive
ORIGINAL: jlrskymaster
i was adding some ultracote - over ultracote - and after i applied it i determined i did not like the look. So, I applied heat again and pulled the trim off. Adhesive was left behind.
What do I use to remove the adhesive?
MEK will take adhesive and any color off the wood. Don't get it on any plastic as it will mar the finish if you try to wipe it off and eat into it if you leave it on.
