removing ultracote adhesive
ORIGINAL: ScaleRCpilot
SeamusG.....Off Topic - How do I go about installing a cool picture under my User name where you have that cool plane?
Thanks! SR/CP
Thanks! SR/CP
One caution, an avatar must be very small. My SSEpic is 7 kb. The original pic is 118 kb.
My Feedback: (16)
CA
ORIGINAL: jlrskymaster
i was adding some ultracote - over ultracote - and after i applied it i determined i did not like the look. So, I applied heat again and pulled the trim off. Adhesive was left behind.
What do I use to remove the adhesive?
