Latency in Elevator Halves
Hello. I was setting up the linkages on my elevator the other night and I noticed that I have a very slight latency on my elevator halves. Ive done some research on this it appears that this is common when mixing dual elevator servos together because the servos will not be perfectly in sync. I'm using the aurora 9, and I'm wondering if anyone can tell me if they also have this problem. If so, do you notice it in flight? This is my first 30cc gasser so i'm going to be pretty particular in my setup on this plane.
My solution will probably be to reprogram the servos and put them on a Y cable. Not sure if I'm just being a little too anal or not.
So I guess the question is: Do you mix your elevator servos? Or are you picky and put them on a "Y"?
