ORIGINAL: harleridr
Bob check out the pics on my first post, first 2 pics show the tracks off the idler after a fifteen minute run second two show before the run.
a TX transplant from Wildwood,NJ
Harle
OK Harle,
GSP exit 4.... If you join the TA Club or come to Danville I may get a chance to meet you. Did you reach out to the Texas club? As for your tank, I still suspect the idler wheel itself or an errant tooth on the tracks. Inspect the idler for wobble (tracks off and make sure the two halves arn't separating under stress. Spin them also and check for distortion. If nothing else works let me know and I'll loan you a good set try out. Also check the angle and make sure the ilders are screwed in true and straight.
Bob
