clutch problems
I'd check your clutch bearings, and also check to make sure your spur gear is not rubbing against the face of the clutch bell. The first thing I would do is pull the engine out and see if the noise is actually coming from the clutch/ clutch bell area, or if it is coming from the truck.
Sean
