clutch problems
Old 08-07-2003 | 07:50 PM
Default clutch problems
If when I turn my flywheel and it makes a rubbing sound could it be that my clutch is going bad and I need a new one, or is there any other problems that could be there?
Old 08-07-2003 | 07:55 PM
I'd check your clutch bearings, and also check to make sure your spur gear is not rubbing against the face of the clutch bell. The first thing I would do is pull the engine out and see if the noise is actually coming from the clutch/ clutch bell area, or if it is coming from the truck.
Sean
Old 08-07-2003 | 09:07 PM
It seems that the car is going slower and it's not switching gears, it stay in first gear.
