RCU Forums - View Single Post - An EPP Wing for a new flyer
Old 12-12-2002 | 06:17 AM
joffacn
Default An EPP Wing for a new flyer
Hi all from Panyu, Guangzhou, China. I am a "newbie" and have a heap of questions. I will probably mail order from the US unless I find a good, knowledgeable store around here.
Is an EPP electric powered Wing (such as the e-Raider from Wing Warrior) a reasonable beginners aircraft?
At least they are tough.
Is there a Rx and/or ESC that would be suitable for both this craft and the Stadium Truck also on my shopping list?
Can Aircraft motors run on the same battery packs as the truck (6 cell 2400 to 3300 mAh, NiCd or NiMH)?
For that matter how much of the electrics and control gear can be used by both?
I will probably buy a Hitec Eclipse7 and grow into it. I am a bit confused over ordering the correct frequency, making changes and re-setting the frequency when I eventually go back to Australia.
Also Rx changes and "programming" servos. I thought you just connected them.
Thanks for any help and suggestions as I have not found a store here or in Hong Kong yet that actually has a knowledgeable person and not just a salesman. Any body lnow of any good stores in Guangzhou or Hong Kong?
