An EPP Wing for a new flyer >
Old 12-12-2002 | 06:17 AM
Default An EPP Wing for a new flyer
Hi all from Panyu, Guangzhou, China. I am a "newbie" and have a heap of questions. I will probably mail order from the US unless I find a good, knowledgeable store around here.
Is an EPP electric powered Wing (such as the e-Raider from Wing Warrior) a reasonable beginners aircraft?
At least they are tough.
Is there a Rx and/or ESC that would be suitable for both this craft and the Stadium Truck also on my shopping list?
Can Aircraft motors run on the same battery packs as the truck (6 cell 2400 to 3300 mAh, NiCd or NiMH)?
For that matter how much of the electrics and control gear can be used by both?
I will probably buy a Hitec Eclipse7 and grow into it. I am a bit confused over ordering the correct frequency, making changes and re-setting the frequency when I eventually go back to Australia.
Also Rx changes and "programming" servos. I thought you just connected them.
Thanks for any help and suggestions as I have not found a store here or in Hong Kong yet that actually has a knowledgeable person and not just a salesman. Any body lnow of any good stores in Guangzhou or Hong Kong?
Old 12-12-2002 | 08:13 AM
Banned
I don't advise a flying wing for beginners. While its possible to eventually learn to fly using one, a "conventional" trainer type with an appearance similar toa Cessna 152 will let you learn faster. The only advantage with the EPP flying wing is that you can keep bouncing it off stuff and not break it. (usually...)
The ESC for the R/C car/truck will have a reverse, the ESC for the aircraft will not. Its not a good idea to have the propellor be able to be powered in a reverse direction on the aircraft. Its not a good idea to go without the reverese on the car/truck. You really would want a separate speed control for each purpose.
Depending on the car/truck and the aircraft, they MIGHT use the same battery packs.
You should be able to find a source for R/C stuff that is closer to you than the U.S. A lot of the kits, electronics and so forth are made in either China or Japan, then shipped to the U.S. Also... you need to be certain that the frequencie(s) of your R/C equipment would be legal in your country. US R/C aircraft radios are on 72 mhz frequencies (mostly...) The cars are on ?75? mhz. (I keep forgetting where they are... I just know its different from the aircraft here and illegal to use a car radio for an aircraft, or an aircraft radio for a car.) In England I think they use 35 mhz for the R/C aircraft. Not sure what they use in China or Australia... If you buy it locally, it should be on a legal frequency.
Note that it is impractical to retune a U.S. radio for the frequencies used in England... It may be impractical to retune a radio that's legal in China to make it legal in Austrailia. CHECK before buying the expensive system... maybe you just want a "disposable" Hitech 3-channel set for a short durration stay in China. (servos, batteries and some stuff won't care what frequency RX you plug them into...)
You can get good advice on-line... go ahead and buy from the store that has salesmen that don't have a clue. Discuss the product specs here, and you should do OK.
Make sure you find someone to help you learn to fly... you learn faster and break less stuff.
