RCU Forums - View Single Post - Problems! Help me Red!
Old 08-07-2003 | 10:16 PM
rplumbo
Default Problems! Help me Red!
I'm having a problem with my electric setup. I'm flying a Zagi with a stock speed control, battery (8c 1700mAh, NiCd), and stock motor. My batteries only cycle to about 1500, and sometimes only 500. I'm charging at .2A and discharging at the same rate (during cycling). The charger also commonly false peaks NiMHs too. I'm using a Triton too. Any tips, or things I could be doing wrong? I feel like I damaged these packs somehow, but that doesn't seem likely as everything is stock and I'm always slow charging.
Another thing, I cycled my Tx pack (600mAh 8c NiCd) and it charged right up to 625mAh. That would seem to indicate that the charger is ok.
I should also mention that my shop supply actually can only deliver 1amp. Is this a problem? I'm always charging at .2A, so I guess in theory it should be okay. (?)
Thanks!
Reid
