RCU Forums - View Single Post - Sickle (V-2)
Thread: Sickle (V-2)
Old 02-18-2011 | 04:06 PM
  #64
cmoulder
Default RE: Sickle (V-2)
ORIGINAL: jlkonn
Bob,
The best thing I found about the Aeropoxy is it stays put.
Doesn't run while it's setting up.
JK
This stuff is GREAT!
The firewall was an awful lot of work as you guys know, with lots of figuring and futzing, but putting together all the advice from the various Sickle threads made it possible. What a relief it is well on the way to being done after spending 2 full afternoons getting to this point. Hope it's quicker next time![X(]
The tip someone posted for transferring the motor bolt template to the firewall worked beautifully. I used some double-sided Scotch tape, a couple of tiny pieces on the end of the motor and then put a lot of tape on the firewall side. All bolts went in on the first try with no misalignment.
A question... After the Aeropoxy cures should I remove the motor and put another bead on the other side of the firewall? Seems like a good idea, or is it not necessary?
ID:	1566058   Click image for larger version
ID:	1566059   Click image for larger version
ID:	1566060   Click image for larger version
