RE: world models t-34
Ihave motors that are 3 and 4 years old and even the original first Ax's and havent had to replace any bearings. After each run, I run the gas out of each engine and then use Rislone Oil to lube up the engines. You can open a single one and never find any rust. If you keep care of the bearings, they last.</p>
