RE: Sickle (V-2)
Hey guys,
I received a bag of 12 flat control horns for the the control surface linkages. Seems to me I should only need 6 (2 for rudder, 1 for each elevator half and 1 for each aileron) is this correct? I have never worked with these before so I assume you just insert in the rectangular slot provided and epoxy right? Looks like the rudder control horns may need to be cut to length to avoid butting up against each other inside the rudder. Is this correct?
Bob,
I 'll be using Futaba BLS153 on the elevator. I still need to order them. When do you think you will be ready for your first flight?
Glen
