RE: Feibao SU 27 Pictures
Hi John
Thanks for the heads up. I removed the retracts and striped and reasembled with locite when I first got the plane and also I have checked and tightened every spar bolt as every one from the factory were very loose same as taileron and rudder spars.This is my third Feibao and by far the one that has required the most amount of work. Yes 2 160s is overpowered but I already had one and they are only 0.2 of a pound differnce to a P80 in weight I will fly it carefully.As for 20 kg well theres nothing I can do about that it has what it needs in it and no more hopefully it will be fine will keep a close eye on everything . I have posted here before about the CG got no replys Is the factory Cg they recommend ok
Thanks Dallas
