Reload this Page >
Feibao SU 27 Pictures
Old 02-19-2011, 05:41 PM
dalbe
Default Feibao SU 27 Pictures
Hi Guys Just a couple of pics of my finished Su 27 ready for Maiden next week.( Thanks Dave & Levi for the help )
ID:	1566705   Click image for larger version
ID:	1566706   Click image for larger version
ID:	1566707   Click image for larger version
ID:	1566708   Click image for larger version
ID:	1566709   Click image for larger version
ID:	1566710   Click image for larger version
ID:	1566711   Click image for larger version
ID:	1566713   Click image for larger version
ID:	1566714   Click image for larger version
Old 02-19-2011, 05:50 PM
Bob_B
Bob_B's Avatar
Default RE: Feibao SU 27 Pictures
WOW that looks incredible!
Old 02-19-2011, 05:55 PM
smaze17
My Feedback: (60)
WOW...beautiful!! I predict you will have a HUGE smile on your face after the maiden
-S
Old 02-19-2011, 06:49 PM
jmalone1982
That is a big beeotch just like the real thing.
Fantastic neat install, Im anal too.
Old 02-19-2011, 06:56 PM
dubd
dubd's Avatar
Looks amazing!
Good luck with the maiden and let us know how she flies!
Old 02-19-2011, 07:01 PM
dalbe
Thanks Guys will try and get a Video of the Maiden
Cheers Dallas
Old 02-19-2011, 07:52 PM
tuan lam
tuan lam's Avatar
how many bl for drying weight ? it looking good and good luck!
Old 02-19-2011, 08:12 PM
dalbe
Hi Tuan lam
It weights 20.125 Kgs Dry.
Old 02-19-2011, 09:16 PM
Levi Wags
Levi Wags's Avatar
That looks so good Big Dal. The weathering came up insane. Now time to fire up those 160s and get her moving lad.
Old 02-19-2011, 09:30 PM
Aussie Bart
Aussie Bart's Avatar
Damn now i'm up for a pair of 200's..........Look forward to seeing it at Wang
Old 02-19-2011, 09:48 PM
dalbe
Yeah mate pray for good weather next week the su and the mig ready to rock :-)) Yeah Bart see ya at Wang 2 200s keen to see what there in lol
Old 02-19-2011, 11:42 PM
Jeremy_D
Jeremy_D's Avatar
Hi dalbe,
I'll try and get up to Maitland on Sunday as well. Got my noew Rookie ready to go, put in 2 flights a couple of weeks ago but was too hot to head up today. (37 deg @ Gosford). I know a few of the Syd boys are planning on getting up there Sunday as well.
Looking forward to seeing it in the flesh!! Looks GREAT!!
Cheers
Jeremy
Old 02-20-2011, 12:06 AM
Levi Wags
Levi Wags's Avatar
ORIGINAL: Aussie Bart
Yeah i think he's got us both covered Bart.
Old 02-20-2011, 12:13 AM
dalbe
Hey Jeremy
Won't be flying it at Maitland way to bumpy Me and Levi and Dave will be going to Evans Head to fly I am over Maitland no more Jet flying there.
Cheers Dallas
Old 02-20-2011, 12:59 AM
Jgwright
Dallas
Very nice finish and a neat installation in very cramped internal space. Wow that did turn out extremely heavy at 20.12 Kg. Mine was with 2 P60's was 14.08Kg, and the prototype with 2 Rabbits was 15.55 Kg. I am worried that it is hugely overpowered and you will have to be very careful. Very few of these models have been flown and yours is by far the heaviest and with by far the most thrust. If I was in your place I would not dream of flying off grass with the weight you have as the U/C gear and retracts is not that strong. The screws on mine all came loose after 2 or 3 flights and I had to take them completely out and strip them down and loctite all the screws. Also make sure you check the aluminium brackets that hold the wing spars and the taileron spars do not work loose. Again mine did after only a few flights. They are a pain being a mix of US and metric threads and difficult to reach as you will find. I just hope the airframe holds together. Good luck.
John
Old 02-20-2011, 02:13 AM
Jason R.
Jason R.'s Avatar
Looks great Dallas hope everything goes well for you next weekend..
ID:	1566853   Click image for larger version
Old 02-20-2011, 02:14 AM
dalbe
Hi John
Thanks for the heads up. I removed the retracts and striped and reasembled with locite when I first got the plane and also I have checked and tightened every spar bolt as every one from the factory were very loose same as taileron and rudder spars.This is my third Feibao and by far the one that has required the most amount of work. Yes 2 160s is overpowered but I already had one and they are only 0.2 of a pound differnce to a P80 in weight I will fly it carefully.As for 20 kg well theres nothing I can do about that it has what it needs in it and no more hopefully it will be fine will keep a close eye on everything . I have posted here before about the CG got no replys Is the factory Cg they recommend ok
Thanks Dallas
Old 02-20-2011, 02:20 AM
dalbe
Thanks Jason
Old 02-20-2011, 02:49 AM
Jgwright
Dallas
The factory position is ok though we used 10mm ahead of the factory position just to be on the safe side. I feel relieved that you did all the checking and tightening, which is absolutely necessary. Some of the screws are very hidden away as no doubt you found. Did you make any improvement to the servo arrangement on the tailerons? On the larger twin F15 models they fit 2 servos. Also I do hope the tailerons are of sound enough construction internally. I witnessed Colins Mirage F1 on its Maiden flight.
The one plus is that we found the plane was like flying a trainer.
Good luck to you.
John
Old 02-20-2011, 03:00 AM
dalbe
John
Thanks for that I have come 5mm forward of what they recommened and will try it there The tailerons are how it came from the factory apart from putting some more Hydrosol around the joints inside the fuse and I balanced the tailerons and it has 32kg Futaba Servos and also I have used none of the Feibao links as I don't think they are up to the job will keep a close eye on it and hope that internally the tailerons are ok.
Thanks Dallas
Old 02-20-2011, 03:07 AM
dave hh
Hey Big Dall looks sweet great job a lot of thought went in to this one, as always a neat install and the weathering really sets it of. Cant wait to see its shapes in the air.
Old 02-20-2011, 03:13 AM
dalbe
Thanks Dave and thanks for all ya help big Fella
Old 02-20-2011, 03:15 AM
JET FX
JET FX's Avatar
Hey Dallas, Looks like the weathering turned out great... Please post some close up pics when you get the chance. Bet you had some fun applying/removing that Good luck with the maiden, she's going to be an awesome bird with all that grunt...
Cheers- Marty
Old 02-20-2011, 03:46 AM
dalbe
Hey Marty yeah thanks for coming up and showing me how to do the weathering I think it turned out really good and thanks for sorting out some of the other Stuff will get some more close up pics.
Cheers Dallas
Old 02-20-2011, 01:16 PM
CHARLES WINTER
CHARLES WINTER's Avatar
Hi Dallas, Looks BEAUTIFUL. I am very anxious to hear and see how it Maidens. I've flown models for over 60 years, from free flight to turbines. I also flew the REAL stuff in the USAF, from T-6, T-28, T-33, F-86, T-38, F-102, F-106 and more. I just want to congratulate you on a "Job Well Done" Attached a few of my Many pictures. Colonel Chuck Winter
ID:	1567110   Click image for larger version
ID:	1567111   Click image for larger version
ID:	1567112   Click image for larger version
ID:	1567113   Click image for larger version
