RE: Feibao SU 27 Pictures
Dallas
The factory position is ok though we used 10mm ahead of the factory position just to be on the safe side. I feel relieved that you did all the checking and tightening, which is absolutely necessary. Some of the screws are very hidden away as no doubt you found. Did you make any improvement to the servo arrangement on the tailerons? On the larger twin F15 models they fit 2 servos. Also I do hope the tailerons are of sound enough construction internally. I witnessed Colins Mirage F1 on its Maiden flight.
The one plus is that we found the plane was like flying a trainer.
Good luck to you.
John
