RCU Forums - View Single Post - On board volt meter - small, light and cheap
Old 02-20-2011 | 02:51 AM
bigplumbs
Banned
Default RE: On board volt meter - small, light and cheap
ORIGINAL: i3dm
Every componenet of our jet had its adcantafes and disadvantages - of course its something that could go bad (although probably unlikely) but it also gives you 100% battery monitoring. its your choice - thas the fun thing about this hobby. just thought i'd sahre the face you can buy a 9$ unit which is much nicer than the 25$+ units.
BTW you could always wire up a proper connector to this unit and use it as a no load external voltage tester.
No problem with you shareing. The item might be for some just not for me. It is also true that a bad battery can give a good volt reading that just goes when it is under load. So in some ways this could be a good thing if you move sever servos when you reaad it
Dennis
