 On board volt meter - small, light and cheap >
Old 02-19-2011 | 01:14 PM
My Feedback: (51)
Default On board volt meter - small, light and cheap
Hey guys,
Check these out, i think they would make a great on board volt meter (small 43mm long and 13g weight) for our jet batteries:
http://cgi.ebay.com/Mini-Red-LED-Vol...item2a05538010
Similar units in the hobby world sell for 25$ + shipping, and these are 9$ shipped.
Enjoy !
Old 02-19-2011 | 01:26 PM
My Feedback: (106)
Default RE: On board volt meter - small, light and cheap
Hey thats a good find. Thanks for posting this!!!! Roy
Old 02-20-2011 | 01:26 AM
lookilook's Avatar
Lior, i use 2 lipos through an emcotech switch, will this work you think? is it connected direct to the battery or y lead to the rx input?
Old 02-20-2011 | 02:06 AM
My Feedback: (51)
in your case i would Y lead 2 units off the batteries directly, to monitor actual battery voltage.
Old 02-20-2011 | 02:12 AM
Banned
More stuff to fit in................ Not a bad find though but dont you think we should be trying to take stuff out of our jets not putting it in.
Simple and light thats what I like
Regards
Dennis
Old 02-20-2011 | 02:34 AM
lookilook's Avatar
thanks Lior,
Dennis a i couldnt agree more..KISS keep it simple safe...
Old 02-20-2011 | 02:39 AM
My Feedback: (51)
Every componenet of our jet had its adcantafes and disadvantages - of course its something that could go bad (although probably unlikely) but it also gives you 100% battery monitoring. its your choice - thas the fun thing about this hobby. just thought i'd sahre the face you can buy a 9$ unit which is much nicer than the 25$+ units.
BTW you could always wire up a proper connector to this unit and use it as a no load external voltage tester.
Old 02-20-2011 | 02:51 AM
Banned
ORIGINAL: i3dm
No problem with you shareing. The item might be for some just not for me. It is also true that a bad battery can give a good volt reading that just goes when it is under load. So in some ways this could be a good thing if you move sever servos when you reaad it
Dennis
Old 02-20-2011 | 05:04 AM
My Feedback: (106)
ORIGINAL: bigplumbs
ORIGINAL: i3dm
Dennis
I don't do just jets, but if this is too heavy for YOUR jets, Don't install one!!!!!!
Old 02-20-2011 | 07:36 AM
Vinceyboy's Avatar
This unit looks identical to the i4c C-Volt meter that came with their Servo Power Regulator, ideal on a small jet where you don't have a Powerbox or switch installed.
Dennis, you really need to build lighter mate
Old 02-20-2011 | 07:39 AM
AndyAndrews's Avatar
just bought one. $5 freight lol. but still seems like a good value.
Old 02-20-2011 | 07:46 AM
My Feedback: (39)
Awesome find i3dm , Thank You.
bigplumbs, give us a break.
Old 02-20-2011 | 08:05 AM
My Feedback: (106)
ORIGINAL: Daleroger
Old 02-20-2011 | 08:33 AM
Banned
ORIGINAL: Vinceyboy
I know Vince but with me being a fat git..... It is difficult
Dennis
Old 02-20-2011 | 08:35 AM
Banned
ORIGINAL: Daleroger
Just a comment it the other direction. I would have thought people would be big enough to accept that. You obviously seem to have a problem with people seeing another side........... Chill
Old 02-20-2011 | 08:56 AM
Vinceyboy's Avatar
ORIGINAL: bigplumbs
ORIGINAL: Vinceyboy
Dennis
I know the problem Dennis old chap, it's a constant battle
Old 02-20-2011 | 09:38 AM
My Feedback: (85)
http://www.xtremepowersystems.net/products.php?cat=19
The TattleTale is a tiny and lightweight device that plugs into a empty receiver channel (or through a Y-cable). This device measures the input voltage and displays the lowest voltage threshold that was captured after being powered on. With a programmable acquisition time of 10ms to 100ms, even the shortest voltage sags can be detected!
This is super small and gives alot of infromation. I have found this very helpful with my jets and planes
Clay
Old 02-20-2011 | 09:50 AM
FILE IFR 's Avatar
ORIGINAL: Wclays
Clay
At 1.75 grams, some may be against the high wing loading, 'extra baggage' their extremely heavy jets have to carry. Check the density altitude at your field before using these products. [8D]
Like Dennis said... "It's just more stuff to fit in".
