RE: Pheonix Extra 330S 60-90 Size
Seeing as some are flying it with a FS91SII, I assume, it will definately fly with a 75AX. What I want to know is, will it 3D with that engine with some authority in the hover? I dont want it to rocket out but the pullout should be sufficient to get out of trouble. A fellow flier has the Phoenix Yak 60" which is essentially the same airplane without the radial cowl. But he is using a 120AX on it. I have a 120AX, but the original idea was to use this airplane as a test bed for the 75AX (which had given me problems earlier) so I want to stick with the 75AX and have fun with it
Ameyam
