RE: 1/16 M16 Halftrack with EL Mod installed
Well actually it does have a EBnet connector and the CSI works just fine..
Additional info: I mounted the EL MOD CSI unit on the deck near the left rear corner of the combat compartment.
It's pretty well hidden by the turret.
The Tower/TBU is mounted in the front right corner just behind the passenger seat.
The Emitter is mounted on the upper left hand 50cal alongside the ammo can, this offers a solid mount point and also allows the emitter to move freely with the guns.
There is also sufficent in the emitter wire length to allow the turret full range of movement.
The present tower/TBU location does not interfear with nor is it tripped when guns are fired.
The floor was notched to allow for the various cables to exit from the main circuit board.
I will try and post some better pics asap.
bullyhys
