RCU Forums - View Single Post - Exponential ? ? ?
Old 02-23-2011 | 06:03 PM
TFF
Default RE: Exponential ? ? ?
You have to use past experience on how much you like and how good your reflexes are. It depends on the exact plane. It is usually is set so the plane does not respond as fast when the stick is moved the first part of its movement but when you move the stick a bunch it moves a lot.
