RCU Forums - View Single Post - Sickle (V-2)
Thread
Sickle (V-2)
02-26-2011 | 01:38 PM
98
cmoulder
Jul 2006
2,819
Ossining, NY
RE: Sickle (V-2)
I still didn't start working on the canopy yet, but some good progress was made in other areas.
Made a template for the belly vent, stuck it on with double-sided Scotch tape and went to work with the Dremel.
Got a Futaba aluminum servo arm for the rudder pull-pull because the round wheel was interfering with the linkage hardware. Located and cut the holes for the pull-pull exits in the fuse and got them pretty close. Pull-pull installed.
Holes cut for the aileron and stab servo wires, and the Tech-Aero switch and the charge port for the second RX battery.
PDF for the Sickle vent is attached if someone wants to use it.
Ce69250.pdf
Reply
Like
cmoulder
View Public Profile
Send a private message to cmoulder
Find More Posts by cmoulder
View iTrader Profile
