RE: OPS 3.5cc FIRE
You don't need to back fill with solder for good running. I think the back filling helps slow down accidental flooding due to pit handling errors. I use 3/32" ID brass tubing for Norvel and Cox .049 taps with no check valve either. Fox sells a steel fitting that has #4 threads that would work well here.
