RCU Forums - View Single Post - Jim Whitley's recommendation in rib cutting.
Old 02-28-2011 | 05:36 PM
R_G's Avatar
R_G
Default RE: Jim Whitley's recommendation in rib cutting.
Brian,
I've done this with 1/16" plywood and it wasn't too bad, but 1/4" would definitely change things quite a bit. With the 1/4" ply you would have to make the tip rib smaller to compensate or taper it.
RG
