RCU Forums - View Single Post - At last wireless simming for Futaba
Old 03-01-2011 | 11:47 PM
ModelGuard.Com
Default RE: At last wireless simming for Futaba
<span style="font-size: larger;"><span style="color: rgb(128, 128, 128);">SimStream</span></span> will work with all Futaba 2.4ghz Fasst transmitters, you will need to change to 7 channel mode in parameters.
Dont forget that <span style="font-size: larger;"><span style="color: rgb(128, 128, 128);">SimStream</span></span> is totaly 'plug and play' no adjustment is usually needed in sim software, The same Transmitter profile is used.
As <span style="font-size: larger;"><span style="color: rgb(128, 128, 128);">SimStream</span></span> uses all Futaba electronics it works flawlessly with zero latency.
www.simstream.co.uk
