At last wireless simming for Futaba
<span style="font-size: medium;">At last we have wire free sim capability for Futaba transmitters.
works with Phoenix, Realflight, Reflex, clearview and others..
<span style="color: rgb(255, 0, 0);">Unleash your Tx</span>
please check out </span>www.simstream.co.uk
Due early to mid March there is 20% discount to all those that pr-register an interest.
Enjoy!
Enjoy!
<span style="font-size: larger;"><span style="color: rgb(128, 128, 128);">SimStream</span></span> will work with all Futaba 2.4ghz Fasst transmitters, you will need to change to 7 channel mode in parameters.
Dont forget that <span style="font-size: larger;"><span style="color: rgb(128, 128, 128);">SimStream</span></span> is totaly 'plug and play' no adjustment is usually needed in sim software, The same Transmitter profile is used.
As <span style="font-size: larger;"><span style="color: rgb(128, 128, 128);">SimStream</span></span> uses all Futaba electronics it works flawlessly with zero latency.
www.simstream.co.uk
www.simstream.co.uk
