RE: G-62 weight?
Mine weighs 4 lbs - 15 oz
It has the CH ignition but this weight is not with the ignition unit.
The CH ignition uses the Zenoah coil and mine has a Bosch shielded plug cap and shielded pilug wire all the way back to the coil per the Toni Clark suggestion.
Mine has the Zenoah flat steel mounting plate
An aluminum Spehar muffler
and the current Zenoah straight pull carb mount
no prop
