RE: Idle problem
It sounds like you have the settings wrong. The regulator screw should be flush with it's housing and you should start with the idle needle at factory setting and high about 2 turns out. I assume you are using an OS F plug. You may want to haul it to the SAMs field, they run alot of YS engines there and are great guys to hang out with.
