ORIGINAL: SyCo_VeNoM
yes it has a fail safe built in
Make sure you read how to set it, and test it first.
Read a post where a guy had his RC go flying into a brick wall when his batteries died or he dropped the remote (forgot which it was but it was awhile ago) due to not setting it
Thanks for that, I'll also be running a throttle return spring as a backup... I also have a remote failsafe that works flawlessly I might decide to use if the one in the Flysky can be disabled. Can you run two??
