Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Truggy
 Can't get servo's to stop chattering!! GGRR! >
RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Old 03-04-2011 | 07:43 PM
Default Can't get servo's to stop chattering!! GGRR!
CRT X1, stock tx and rx, all fresh charged batteries, Futaba S9451 throttle, Airtronics 94161 steering... Both servo's chatter at the same rate to the point where it's impossible to run smoothly, it either dies or goes nuts... Need a little help on this one... Suggestions? All wiring and switch seems to be intact and functioning properly. It's been sitting for a few months but I wouldnt think that would be an issue. They've always chattered a little but not to this extent.
Old 03-04-2011 | 08:24 PM
nitroexpress's Avatar
Default RE: Can't get servo's to stop chattering!! GGRR!
ORIGINAL: Spdfrk
I'm guessing that your radio is not a DSM 2.4ghz system. If so, your probably getting interference.
Old 03-04-2011 | 08:27 PM
ORIGINAL: nitroexpress
ORIGINAL: Spdfrk
I considered this as a possibility, however, it's always worked fine in the past and nothing's changed,. Same thing even if it's isolated from all potential interferance sources such as florescent lighting and the like. All other radio systems work normally.
Old 03-05-2011 | 01:20 PM
Anyone else? I'm stumped and the sun's shining...
Old 03-05-2011 | 01:52 PM
SyCo_VeNoM's Avatar
try another radio with the servos IMO
If that fix's it throw the AM one in the garbage and pick up a 2.4ghz radio.
Flysky 2.4s are pretty good and cost $20 from hobbypartz shipped. I use one in my Jammin X1 CRT, and use the multi-model flyskys in 12 or so (don't feel like counting) other RC's
Old 03-05-2011 | 02:06 PM
schuttman's Avatar
From: m\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'boro, TN
Try the crystals....
Old 03-05-2011 | 02:13 PM
ORIGINAL: SyCo_VeNoM
Wow! That Flysky looks like a heck of a deal! Think Im gonna get one just for the hell of it! Thanks!
Old 03-05-2011 | 02:15 PM
ORIGINAL: schuttman
You mean swap out the current ones with another set? I can do that..
Old 03-05-2011 | 02:18 PM
schuttman's Avatar
yep thatwill be the cheap way to go at first
ORIGINAL: Spdfrk
ORIGINAL: schuttman
Old 03-05-2011 | 02:50 PM
Does the Flysky have a built in failsafe as well?
Old 03-05-2011 | 03:06 PM
Argess's Avatar
Sometimes metal geared servos get damaged in a crash. Then the metal gears rub loosely and cause EMI which can cause glitching.
So both servos chatter? Temporarily disconnect one and see if the other stops chattering. If not, plug it back in and disconnect the other servo.
If it's not the servo, you can check the receiver if you have a spare.
As it was working before, a crash may have caused the trouble. Look for chafed or pinched wiring.
A wonky ON-OFF switch has caused more trouble..... Try plugging the battery directly into the Rcvr and see what happens.
I hate it when Instruction Manual troubleshooting merely says "check the batteries", but do it anyway. And remove them and look for corrosion in the battery holder as well.
Now here's a silly one....got ABS on your radio? Sure it's not somehow set ON all the time?
Anyway, try some things and then let us know what you've tried and we maybe we can think of a few more things to try.
EDIT: Ooops...missed where you said new fresh charged batteries.
Old 03-05-2011 | 03:13 PM
ORIGINAL: Argess
I hate it when Instruction Manual troubleshooting merely says ''check the batteries'', but do it anyway. And remove them and look for corrosion in the battery holder as well.
Hey, thanks for that... I did the servo thing and they still do it on an individual basis... Im gonna jack with ist a little more tonight and Ill try all of your suggestions... Either way, a Flysky is on its way, has to be better than the stock Ofna AM settup... This vehicle has been a shelf queen and a backyard runner most of its life so its never suffered any crashes hard enough to do that kind of damage... Im kinda leaning torards a skrewy rx...Thanks! Whats ABS?
Old 03-05-2011 | 03:42 PM
Argess's Avatar
Yes, it's likely a screwy RX.
Your radio doesnt have it, but ABS....anti-lock brakes. I'ts kind of weird to set up ABS and I could see it coming on.
Hope you like the Flysky....if it's the one I'm thinking of, it's a very inexpensive 2.4GHz system with really inexpensive receivers. I'm thinking of getting one and a bunch of spare Rx's so I use one radio for all my vehicles.
Old 03-05-2011 | 04:13 PM
ORIGINAL: Argess
For less that twenty bucks, it has to be an upgrade from stock. I'll post my thoughts after I run it a while. It'd be nice to read other peoples opinion of the Flysky radio in question..
http://www.hobbypartz.com/fs-gt2-24ghz-radio-black.html
Old 03-05-2011 | 05:10 PM
SyCo_VeNoM's Avatar
yes it has a fail safe built in
Make sure you read how to set it, and test it first.
Read a post where a guy had his RC go flying into a brick wall when his batteries died or he dropped the remote (forgot which it was but it was awhile ago) due to not setting it
Old 03-06-2011 | 04:46 PM
Thanks for that, I'll also be running a throttle return spring as a backup... I also have a remote failsafe that works flawlessly I might decide to use if the one in the Flysky can be disabled. Can you run two??
Old 03-06-2011 | 05:00 PM
SyCo_VeNoM's Avatar
[quote]ORIGINAL: Spdfrk
no you will cause issues.
If I remember it right the flysky will not work with any other failsafe.
Old 03-06-2011 | 05:05 PM
[quote]ORIGINAL: SyCo_VeNoM
ORIGINAL: Spdfrk
Do you know if the Fkysky's failsafe can be disabled?
Old 03-07-2011 | 02:10 PM
Anyone ever tried these batteries from Hobbypartz?
http://www.hobbypartz.com/73p-23a1600-5-m.html
Old 03-30-2011 | 05:51 PM
The Flysky radio system is unreal for the price.... Put a new battery in the truck and all seems well..
