RCU Forums - View Single Post - plastic to wood prop
Old 03-07-2011 | 05:34 AM
CGRetired's Avatar
CGRetired
Default RE: plastic to wood prop
Well, the point here is thrust and RPM. You will get the same thrust out of the wooden prop as you will with the other one of the same size. That's just the physical aspect of the prop dimensions.
If the engine can turn the larger prop at a working RPM that is agreeable with you, well, it will certainly be a tad bit quieter.
CGr.
