RE: KO Propo EX-5 UR
Hello again,
I've made up a croc clip charging lead and I can now charge the TX batteries quite happily, they are 3600mah so hopefully this 2.4 system wont drain them too quickly?
However, I seem to have developed a problem with my steering servo its rather twitchy when I turn the steer wheel, especially when its at the end point. When I release the steer wheel back to neutral it calms down......if I don't turn the steer wheel there is no movement/ twitching so maybe it's not interfererence?? It doesn't do it when I use the old AM radio setup so hopefully the servo isn't busted so I'm unsure what the problem is........the throttle servo had a similar issue but by adjusting the end point/ trims it seems to have stopped but it was with more luck than judgement...
any clues/ opinions always appreciated
cheers
