RCU Forums - View Single Post - Help me with my Extra!
Old 03-08-2011 | 08:57 PM
KitBuilder's Avatar
KitBuilder
Default RE: Help me with my Extra!
ORIGINAL: cl0ckwork
1. Can I get bubles out of the body of the plane using an iron or heat blower?
###YES
2. I need some advice on what to do about the cowl. I do not have the one that came with the plane. And the item is discontinued
###Fiberglass Specialties may have it.
3. What servoes should I look for? I need to make sure they are strong enough etc. I know there are a min of 5 needed, possibly 6. It has been so long since I have been in the buying market and I am not up with all of the terminology. I just purchased a Futaba with 5 servos and reciever online. What do I need to look for to make sure they are strong enough?
###That looks like a large Extra if its sitting on twin bed> .. ball bearing / high torque servos would be my guess.
Any advice you guys might have for me before I buy all my supplies/field box would be helpful!
###With that said.. your going to be spending some $$$on a motor and other items to get her up the "code" It looks a bit rough presently and I'm not so sure that airframe is up to snuff safety wise as this is a plane that will experience some strong stresses and the components (control horn mounts, hinging, wood itself, etc)may no longer be up to the task looking at what seems to be fuel residue that may have been sitting for a bit.
###For what it's going to take to get that model flying reliably and safely, if it were me, I would pick up a current ARF which is proven and gives a much better chance of success which would also be aerobatic. You could always work on the extra on the side taking your time since you'll havea plane to fly and be much less likely to rushgetting the extra in the air.Just some thoughts to chew on....
