RCU Forums - View Single Post - New Build
Thread: New Build
Old 03-14-2011 | 11:40 AM
gregjones
Default New Build
Hi,
I have a boat shell on back order with Hobby King. It is a Hobbyking vanquish brushless V hull 1075cm. The site says "The Vanquish is a large (1.075mtr) V-Hull fiberglass racing boat kit ready for your own choice of EP setup. All quality hardware is supplied including a water jacket for the motor and cooling system tubing. You will require a36xx size <span onclick="window.open('tips.asp?idtip=21','Tooltip2 1','menubar=1,resizable=1,width=450,height=250');" style="cursor: pointer; border-bottom: #0f0 1px dotted; text-decoration: none">brushless</span> inrunner motor around 2200<span onclick="window.open('tips.asp?idtip=2','Tooltip2' ,'menubar=1,resizable=1,width=450,height=250');" style="cursor: pointer; border-bottom: #0f0 1px dotted; text-decoration: none">kv</span>, a Standard size servo with 3kg or more of torque, a 125A to180A Water cooled <span onclick="window.open('tips.asp?idtip=3','Tooltip3' ,'menubar=1,resizable=1,width=450,height=250');" style="cursor: pointer; border-bottom: #0f0 1px dotted; text-decoration: none">ESC</span>m,a 2 Channel radio system and either two 2s~3s 5000mAh batteries or a single 4s~6s 5000mAh battery".
What would you suggest would be my best set up from the parts listed below? I have a couple of Turnigy 5000 mah 4 cell 14.8v batteries that I would like to utilise if I can. I am a bit confused about all the ESC sizes etc. They dont seem to list the motor that they recommend. Any alternatives?
Thanks greg<font face="Verdana" color="#ffffff" size="2">bbyKing Vanquish Brushless V-Hull R/C Boat - 1075mm (KIT)</font>
<font face="Verdana" color="#ffffff" size="2">HobbyKing Vanquish Brushless V-Hull R/C Boat - 1075mm (KIT)</font>
<table cellspacing="1" cellpadding="0" width="100%"> <tbody> <tr> <form action="uh_addItem.asp" method="post" name="quickadd3743"> <td></td> <td></td> <td><font style="font-size: 9px">HXT 6.9kg / 39.2g / .16sec Twin bearing servo</font></td> <td>IN STOCK</td> <td>$5.95</td> </form> </tr> <tr> <form action="uh_addItem.asp" method="post" name="quickadd5426"> <td></td> <td></td> <td><font style="font-size: 9px">SSV 42g / 9.7kg-cm / .12sec Servo</font></td> <td>IN STOCK</td> <td>$12.95</td> </form> </tr> <tr> <form action="uh_addItem.asp" method="post" name="quickadd8746"> <td></td> <td></td> <td><font style="font-size: 9px">BMS-410STD Standard Servo 4.4kg / .22sec / 42g</font></td> <td>IN STOCK</td> <td>$8.60</td> </form> </tr> <tr> <form action="uh_addItem.asp" method="post" name="quickadd8937"> <td></td> <td></td> <td><font style="font-size: 9px">Turnigy Marine 180A Brushless Boat ESC</font></td> <td>IN STOCK</td> <td>$89.99</td> </form> </tr> <tr> <form action="uh_addItem.asp" method="post" name="quickadd8946"> <td></td> <td></td> <td><font style="font-size: 9px">Turnigy Marine 120A Brushless Boat ESC</font></td> <td>IN STOCK</td> <td>$49.99</td> </form> </tr> <tr> <form action="uh_addItem.asp" method="post" name="quickadd9963"> <td></td> <td></td> <td><font style="font-size: 9px">ZIPPY Flightmax 5000mAh 4S1P 40C</font></td> <td>IN STOCK</td> <td>$51.09</td> </form> </tr> <tr> <form action="uh_addItem.asp" method="post" name="quickadd10307"> <td></td> <td></td> <td><font style="font-size: 9px">Turnigy 5000mAh 4S 40C Lipo Pack</font></td> <td>IN STOCK</td> <td>$64.71</td> </form> </tr> <tr> <form action="uh_addItem.asp" method="post" name="quickadd10608"> <td></td> <td></td> <td><font style="font-size: 9px">Hobby King GT-2 2.4Ghz 2Ch Tx &amp; Rx </font></td> <td>IN STOCK</td> <td>$16.59</td> </form> </tr> <tr> <form action="uh_addItem.asp" method="post" name="quickadd11957"> <td></td> <td></td> <td><font style="font-size: 9px">Turnigy nano-tech 5000mah 4S 45~90C Lipo Pack</font></td> <td>IN STOCK</td> <td>$75.99</td> </form> </tr> <tr> <form action="uh_addItem.asp" method="post" name="quickadd12177"> <td></td> <td></td> <td><font style="font-size: 9px">HK-300 3 Channel 2.4ghz FHSS Ground Radio</font></td> <td>IN STOCK</td> <td>$19.80</td> </form> </tr> </tbody></table>
